Upvote 4
Aloha not working with mac m1 ventura
Completed FEARLESS_TR ● 3 years ago
Hi guys i am first time using this app subed for 1 year plan but its not working on macos ventura app is just loading loading endless and when i click on settings button on app its closing it self but still running on background and blocking my network until i restart my mac doenst work.If this app not compatipel with mac apple silicons i gonna return my money sorry.
8df8b60530107f96ddecc11f80ebd034
Replies (2)
Hey no help ?
We are looking into it 🛠😉
Hi there,
Please open System Settings on Mac and check if Aloha VPN is in the list. If you find it there - please delete it, then try to install Aloha VPN profile once again in the application. Let me know if it works afterwards 👍
Whic system setting, network ?
and you cant now open settings in aloha , aloha app closing it self setting has no fonction right now its need a new update , or i gonna report it to apple because this app not compatibel with mac os ventura
You can remove Aloha VPN in Mac (not Aloha's settings) settings:
12e02e85bb20ad36e173d6c3a1704824
Try this step first and then let me know if it makes any difference.
i did it stil not working, its say connection but nothing happening
Try one more method:
- close Aloha VPN app
- open Applications folder in Finder
- right click on Aloha VPN app
- click on “Get Info”
- enable “Open using Rosetta” (if Rosetta not installed - installation dialog will pop up, approve installation)
- after installation run AlohaVPN one more time
- enable VPN
This should do the trick.
Why just not update it isnt simple ?
And its working right now thanks for help but its need a apple silicon support, i used it before on my ipad its realy great app, and 1 more question is there any way to use this app same in ipad or need a get new license ?
You can use one subscription for all Apple devices with the same Apple ID - tap 'Restore Purchase' button in Aloha app settings to activate it 👍
Hi, I have the same issue with my M1 Ventura Macbook, but neither fix works. My phone works fine so for now I have to download files to my phone and then AirDrop to my Mac, but that's a bit cumbersome. I can't wait till there's an official release for this app.
