Severe download problem
Hi, I’m having issues with the Aloha browser app for iPad. There’s a problem when downloading videos no matter the web page or quality of it. Let’s suppose I download 6 videos, all are from the same source but different episode and similar size but, half of them take 60 to 100 TIMES LONGER to download. Some take hours for the download to complete while others take 30 seconds at most. It’s not an internet problem nor a problem of the webpage since different sources have been tested as well. This problem has been persisting for a while now and I’ve wrote a few reviews every time a new update is available but the problem is still persisting and no answer received yet. It’s really annoying specially when you are watching videos in order but ep 1, 3, & 5 are completed but 2 & 4 are still on 3.3 kB out of 300 mB. This app was perfect but now with this issue it’s easier to download stuff on a computer and then pass them to my iPad... Just in case my VPN is turned off and problem persists with VPN on as well. I’m leaving two pictures as examples. Ep 1 and 3 are downloaded but ep 2 is still downloading at a really slow rate.
Just in case, it was perfectly fine when I started using this app but after a few months of using it this problem appeared.
Hi, Alexan
Thanks for posting!
In this case, please try the multithread downloading. It has a flexible possibilities for different cases.
We recommend using it this way:
I hope this helps!
Take care,
Aloha team
Hi, Alexan
Thanks for posting!
I hope this helps!
Take care,
Aloha team
Hi again, thanks for the prompt response. What if I don’t pay for Aloha premium? I’m not interested on having VPN or multi threads. Back then when 1 download at the time was the maximum limit and no multithread (With premium) option was available the downloads worked just fine without having to pay. This issue can’t be looked into? As you can see, this issue limits the speed at which some downloads (randomly, 1/3 to 1/2 of them) are downloading by a lot (reaching from 0 to 30 kB download speed) and this doesn’t seem normal. Having to pay for premium to see if this download issue is fixed is not what I was expecting and from the beginning it wasn’t on my plans. That’s why I contacted you to see if this bug was known, can be fixed or looked into. I’ll be waiting for a response, thanks for your time and consideration.
Hi Aloha Team, I can't download music using my Aloha app. Don't know what is actually wrong please help.
Margaretenow619@gmail.com
Thanks.
Thanks.
Comments have been locked on this page!
