- Open the web3 site in your browser where you connected your Aloha wallet
- Tap the menu in the address bar (lock icon on the left)
image - Then tap the “Disconnect wallet” button
image - Confirm the action in the pop up dialog box.
General Settings
- Create Wallet
- Import Wallet
- Import Tokens
- Backup / Setup Wallet
- Change Network
- Add Network
- Delete Network
- Add Token
- Hide Token
- Search Tokens
- Cancel Transaction
- Send
- Buy
- Receive
- Swap
- NFT Premium
- Send NFT
- Hide NFT
- Unhide NFT
- Search NFT
- Connect Wallet to Web3 Site
- Sort Tokens (Settings)
- Reset Wallet (Settings)
- Show/Hide Wallet Balance
