To import an existing wallet, tap the Aloha Wallet within Aloha app, then select 'Import Ethereum wallet".
You will be presented with a box with which you must enter your secret key word phrases, usually between 12-16 random words. Enter them in the correct order carefully. Then press continue to import your wallet.
