1. In Aloha Wallet you are able to swap tokens in decentralised way
2. Tap the Swap button
3. Accept terms and conditions
4. Select the Network ( Ethereum, BNB, etc.)
5. Select the token and the amount, then tap Continue
6. Check the data and swipe the button
