There are three options to add the Binance Smart Chain network. You can choose any that suits you best.
How to add the Binance Smart Chain (BSC) network using the network switch dialog box:
Open the configured Aloha Wallet
On the main wallet screen, click the network icon located at the top that displays the current network you are on
In the dialog box that appears, click on the "Add Network" button at the end of the list. Then fill in the fields as follows:
Name: Binance Smart Chain
RPC URL: https://bsc-dataseed.binance.org/
ChainID will be automatically filled in.
Symbol: BNB
Block Explorer URL: https://bscscan.com (or another source of information).
Click the "Add" button in the upper right corner to save the Binance Smart Chain settings. Once its done, you will see a network switch dialog box. If you wish to switch to the new network, you can do so with a single click. Now you can send, receive, and store Binance Smart Chain and tokens based on this network in your Aloha Wallet.
Do you want to add the Binance Smart Chain (BSC) network through settings? Follow these simple instructions:
On the main wallet screen, click the settings icon located in the upper right corner.
Select "Networks," and you will see a list of existing networks and "Add" button to add a new network in the upper right corner. Fill in the fields following the instructions to add the Binance Smart Chain network.
Symbol: BNB
Click the "Add" button in the upper right corner to save the Binance Smart Chain settings. Afterwards, you will see a network switch dialog box. If you wish to switch to the new network, you can do so with a single click. Now, you can send, receive, and store Binance Smart Chain and tokens based on this network in your Aloha Wallet.
How to add the Binance Smart Chain (BSC) network using the web3 website:
Open the web3 website in Aloha Browser, where you can add a network. For example, we will use www.chainlist.org.
Go to the website and find the list of networks. Select Binance Smart Chain Mainnet and click the "Connect Wallet" button. Afterwards, you will see a dialog box with information text and "Add" and "Reject" buttons. To add the network, swipe the "Add" button. The network will be automatically added, and if necessary, you can switch to the added network using the "Switch" button, which will appear immediately after adding.
