1. Go to Wallet
2. Tap 'All Tokens' in the lower middle corner
3. Then tap three-dot icon in the upper right corner
4. Select 'Import Tokens' in the pop up menu
5. Tap 'Import'
1. Go to Wallet
5. Tap 'Import'
