1. Go to Aloha Wallet
2. In the NFT menu, tap the 3-dot icon
3. Then tap View Hidden
4. Select the hidden NFT from the list that you wish to unhide
5. Tap 3-dot icon in the right corner - tap Unhide.
Aloha Wallet
- Create Wallet
- Import Wallet
- Import Tokens
- Backup / Setup Wallet
- Change Network
- Add Network
- Delete Network
- Add Token
- Hide Token
- Search Tokens
- Cancel Transaction
- Send
- Buy
- Receive
- Swap
- NFT Premium
- Send NFT
- Hide NFT
- Unhide NFT
- Search NFT
- Connect Wallet to Web3 Site
- Sort Tokens (Settings)
- Reset Wallet (Settings)
- Show/Hide Wallet Balance
