- Log in to Aloha Wallet
- Open any web3 site in your browser (for example: https://rarible.com/)
- Open the web3 site menu (top right corner) and tap the “Connect wallet” button
- Choose the “MetaMask” wallet from the available list
- Swipe the “Connect” button in the appearing dialog box
- If needed, give permission to the web3 site to access your wallet.
Aloha Wallet
- Create Wallet
- Import Wallet
- Import Tokens
- Backup / Setup Wallet
- Change Network
- Add Network
- Delete Network
- Add Token
- Hide Token
- Search Tokens
- Cancel Transaction
- Send
- Buy
- Receive
- Swap
- NFT Premium
- Send NFT
- Hide NFT
- Unhide NFT
- Search NFT
- Connect Wallet to Web3 Site
- Sort Tokens (Settings)
- Reset Wallet (Settings)
- Show/Hide Wallet Balance
