1. Enter Aloha Wallet
2. Tap NFT button
3. Then tap 3-dot icon in the middle right corner
4. Tap Hide.
Aloha Wallet
- Create Wallet
- Import Wallet
- Import Tokens
- Backup / Setup Wallet
- Change Network
- Add Network
- Delete Network
- Add Token
- Hide Token
- Search Tokens
- Cancel Transaction
- Send
- Buy
- Receive
- Swap
- NFT Premium
- Send NFT
- Hide NFT
- Unhide NFT
- Search NFT
- Connect Wallet to Web3 Site
- Sort Tokens (Settings)
- Reset Wallet (Settings)
- Show/Hide Wallet Balance
