How can I export my Bookmarks from Aloha to other browsers?
1. Open Aloha Lite app
2. Go to Bookmarks section:
4. Select 'Export' bookmarks:
5. Find your bookmarks file in your device's file manager in Downloads section with the title 'AlohaBrowser_Bookmarks'
6. Select the file and share it to any app in the menu: email/drive/messenger/other
7. Save your bookmarks file (html) from your email/drive/messenger/other to your PC/MAC and add it to any browser you like.
Is article helpful?
