How can I transfer Aloha downloads from one Android device to another?
For Premium users
Wifi file sharing
Friendly note: if you are not a Premium user, you can sign up for a free weekly trial and unsubscribe at any time!
Here is why we recommend it:
1. Sharing through the cloud requires cloud (which is also a paid service), at times it's very slow (files are uploaded, and then downloaded again), so if you have, say 15GB of files it will take forever. Wifi file sharing goes through wifi without spending data and it's ten times faster than cloud. Try it for free!
For Standard Aloha users
File transfer via cloud & file manager:
1. Go to Aloha browser downloads section
2. If you wish to transfer your private files, firstly move it to public folder:
- Enter Private folder
- Long tap any file and then select all remaining files in private folder
- Tap 3-dot icon in the upper right corner and move selected files to any public folder
3. Go to device file manager
4. Enter AlohaUserDownloads
5. Select all files and tap Share button
6. Choose any cloud (dropbox/google drive/etc.) in the share menu and store your files there
7. In your new Android device open your cloud and share Aloha files to Aloha app.
File transfer via SD card:
-via device File Manager:
1. Firstly, if you have any files in Aloha Private folder, move it to public folder:
- Go to Aloha downloads
3. Then go to device file manager
4. Enter internal Storage
5. Open AlohaUserDownloads folder
6. Select all files and move it to SD card
7. Remove SD card from device and insert to another Android device
8. Then go to device file manager -> SD card
9. Select all Aloha files
10. Tap 'Move' in the file manager menu and choose AlohaUserDownloads folder in your internal storage.
Bookmarks transfer:
2. Enter Bookmarks section in the toolbar
4. Select 'Export' bookmarks in pop up menu
5. Find your bookmarks file in Aloha Downloads section with the title 'AlohaBrowser_Bookmarks'
6. Tap 3-dot icon in the lower right corner of the file
7. Tap Share in pop up menu
8. Choose any app in the list- email/drive/messenger/other
9. In another Android device, save your bookmarks html file to device storage from your email/drive/messenger/other
10. Then go to Aloha application
11. Enter Bookmarks section in the toolbar's menu
12. Tap 3-dot icon in the upper right corner and select 'Import Bookmarks'
13. Find and tap Alohabrowser_Bookmarks html file from device storage and it will be imported in Aloha bookmarks section.
Is article helpful?
5 0 2
